951 X Over to Wastgate Pipe Needed
Wondering if any one has an extra exhaust pipe that connects the X over to the wastegate. When I pulled my X over off I found the inside weld was broken all the way around meaning a pretty big leak to the wastegate. Im hestitant to have it rewelded so I dont mess with the flow but am looking at rewelding as a last resort.
Brian
Brian
Remember, there are two different styles of two piece crossover ...
I would just have someone weld the pipe who is competent with inconel. You can line it up on the break, clamp it and weld it around the outside. Any penetration can be ground down with a pencil grinder or something similar, and the same goes for excess weld obstructing the bolt heads. Fretting about gas flow to that extent is overkill; unless you're custom-designing exhaust components to exhibit specific wave characteristics, the difference is insignificant.
Most people won't sell the short pipe by itself anyhow, so you'd be looking at ~$150 for an entire two-piece.
Also - there are two different setups for the two piece crossover. Might want to post of pics of the part that you need to make sure you get the right one.
![](http://members.rennlist.org/jjbare/ceramic02b.jpg)
My car is an 89 so I need to later 2pc model. Tconn I will take the one you have if you will part with it. I sent you a PM. This is the piece in the PET catalog
![](http://www.geocities.com/xupkid2/xover.JPG)
Brian
Brian
