Re Start 90 951
In have not started my 90 951 in over a year. Fuel has stabilizer, and octane boast.
How should i go about starting? pull the wires and turn over?
Car has 42,000 miles...
Thanks,
Doug
Thanks,
Doug
I've been there. My 89 951 started and drove just fine after 16 months parked in the garage.
Charge the battery
Check all fluids, tire pressure
(Might look for cobwebs)
Start and run for awhile
Then change the oil
Drive around and use up the old gas
Charge the battery
Then change the oil
I was looked for something like this. 16 months - and there you go huh? .. love this car. (Fluff the pillow and sleep like a baby)
Spell Checker
Drain what little gas you have. It is super easy. You can get to the fuel pump right next to the gas tank with an easy lift. For the few bucks, just pitch it. The pump is so low, asi it should be, just let it drain. If you need direction let me know.
