turbo water pump wire cracked
A tight wrap of Scotch 33+, followed with a small controlled application of 3M "liquid tape".
Allow to set up at least 30 minutes prior to re-installation.
Will you hurry up and get that thing back together!
The repair option I listed will work fine and last for quite awhile. I forgot to add to clean the wire back about 4 inches with rubbing alcohol/wipe/and allow to dry....THEN apply the 33+ and liquid.
I would only use the solder idea if the wire is partially broken or weak from being worked back and fourth too much (work hardened). Otherwise a drop of silicone or liquid tape as suggested.
1. why do you have a gold bracket?
2. real smooth with the fake the ID
3. Junk that thing your going to be chasing shorts for as long as you have that pump. I think i have one you can use
