PO + Scotch Tape = ? **pics attached
I was out replacing the vacuum lines when I stumbled upon this beauty. What is this hose used for? Where can I get a replacement?
(and yes that is scotch tape holding the two hoses together)
It is a return line from the cycling valve (stock boost control) to the intake boot. But more importantly, it is a leak in your intake system, and is messing with accurate metering of your air intake.
