Low Oil Pressure Problems
Hey guys,
So recently I was driving my car and notices at idle the pressure was dropping to below 1 bar (UHOH). I drove it home keeping the revs up, and changed the oil. I started the car it didn't have pressure for about 30 seconds then it jumped up. When it did jump up it went all the way to 5. After the oil warmed up it was still low when ideling (light comes on).
I know that:
1. It is not a loose connection to the sender unit, I hear the lifters when its low on startup.
2. It is nothing to do with the filter, it is a mahle filter with the anti drain back
Could the OPRV be stuck open, providing low pressure?
I have a video of the car revs/pressure that I will post a little later once i get it off my phone. Thanks for the help. (The car is an 87, should be the one piece valve).
Jeff
I know that:
Jeff
Rocket Scientist
I would start with the OPRV. You could remove it and try cleaning it before buying a new one. Why did you decide to change the oil to solve the problem? Was it past time for an oil change? I only ask because that could possibly lead to the OPRV sticking from junk in the dirty oil.
...you didn't change brand/Visc of oil at the same time did you?
I feel like if the crank bolt loosens then it will just be low, it wont be 0 for 30 seconds at startup then pick up right? That doesnt seem to make sense to me.
Whoops, I was responding to checking the o-ring on the OPRV. I doubt it is the guage as people are suggesting, I hear lifter noise when the guage is reading 0.
If you need a spare OPRV to test with I've got one that you can borrow for shipping costs - just PM me your address. The other thing I would check if I were you is the oil cooler thermostat. Easy to get to like the OPRV. Just fixed oil pressure issues on my car where this thing was no good and I've got an 87 951 with approx 130k as well.
