best battery for cold weather/sitting for longer periods
Hey all...I am pretty sure my best option here is the Optima yellow top right? If so, are there any fitment issues? It looks like it is a pretty tall battery.
Any other preferred options? Thanks
With exception of dry cells (optima), nearly all other lead cell batteries are made by the same company under different brands. Best thing for cold long winters is a trickle battery tender. Just hook to battery and it will trickle charge somewhere between .5A to 2A depending on brand keeps battery warm.
thanks but that's not really an option as the car is outside (and under cover). My current battery is not holding a charge well and I need to replace it so I am trying to select the best option given my situatioin...
I've had the Optima Red Top. It lasted 7 years here in the desert. I then went to a Marine Optima Blue Top. I have a nasty electical drain I can seem to find. It just went out after 5 years. They are the best. Every other battery I've ever had lasted less than the warranty and they woulnd't give me a warranty replacement since I'm in the desert. You just have to mount it on it's side. No big deal. DO NOT MOUNT IT STRAIGHT UP. It looks like it may clear but it won't. I watched someone else try to prove me wrong. Looked like the fourth of July under his hood. Here's my set up.
Why not just disconnect the battery? Or put a battery tender under the hood and just run a extension cord out to the car? Or keep the battery tender inside and run their extension cable out to the car? It doesn't matter what kind of battery you have if you have a key-off draw - it will always end up draining the battery if the car sits for extended periods of time.
Probably because you were vague on what you're trying to achieve. An Optima won't give you anything over a new Pb/acid with what you're trying to do. If you want an Optima, buy an Optima. Don't expect it to do any better if it gets drained and make sure you follow the proper recharge procedure if it does.
I'm partial to my $15 Interstate blem
I have the same problem with my car in cold weather it never starts well and the battery will die pretty quick. rite now i just disconnect the battery and i dont get to drive it often any way cause of the weather but i was thinking of putting in a battery cut off switch. has anyone done this or have any opinions on doing so?
