Injector Suggestions
Wanted to start a thread on injectors since I want to change mine and wanted some suggestions.
Should I go with 72#. I'm kinda scared it will affect low rpm throttle response...
Shoot away!
Shoot away!
Small Business Partner
Try looking at these:
Racetronix Delphi 75lb/hr
They have a fairly wide spray angle - 22.5 degrees, are ball and seat design, and flow-matched to 1%. You most likely will have to increase the dead-time value, but that should be easy enough. They are low-impedance, so you might want to add ballast resistors (some guys run with, some without). Price is nice too.
-Rogue
-Rogue
