951 Temperature
Well how about an oil cooler? Do you think that is a SMALL difference, between a 924s and a 951? ROFL.
AZ already handled the rest of the differences.
Unless you are running a car on the track, there are very few (read almost NONE) cases where the oil is going to get so hot that it will heat soak the coolant to a point where the oil brand or viscosity will EVER make a significant difference...damned sure not in a street car!
Even with lighter viscosity oil, you aren't going to see any actual difference in a street application, in terms of performance. You aren't on the street looking for 1/100th of a second over the course of 50 laps.
Sometimes it's astounding how much effort gets put into meaningless tech, by the owners of street cars, on this board.
If you aren't going racing, run the oil that best protects your engine. PERIOD.
Funny, I just noticed my car doing the same thing (and I'm just up the road from you). I don't recall it doing this last winter. I did have the thermostat cooling housing off this summer and wonder if I might have mucked something up when I put it back together (ala Special Tool's comment).
Did your engine builder suggest running such low visc oil during a run in period? Why did you need a new engine? What oil were you using before? You know the Porsche handbook suggest 20w/50 even in sub freezing conditions. Sure, your 10w/30 is there too but unless your after extended fuel economy vs extended engine life you might consider moving up in weight after a few more miles.
I took my 951 out of mothballs today for drive and was surprised about how cool it was running. I am wondering how much impact moving to Royal Purple 10W-30 XPR racing oil had on temperature. RP claims that it is signficant.
It is 45 degrees in Seattle today. I had the heater on at a low setting. I drove the car for an hour and the temperature guage read:
About the car:
- 2500 miles on rebult motor
- New radiator
- Water wetter
- Additional external oil cooler
- 16 PSI max boost
- 14.7 AFR off boost
- 11.9 AFR on-boost
Oil pressure: 3.75 at idle, 5.0 at light throttle.
The RP has completely eliminated all engine noise at start up. It might be my imagination, but the engine seems smoothier and slightly more responsive.
RP's ads claim a drop in operating temperatures. I took this with a grain of salt since it could be marketing hype. I am beginning to think otherwise.
Does anyone have experience with RP XPR reducing operating temperatures?
Is it actually harmful for the car to run too cool since it was designed to operate at a specific temperature range?
- Extended idle: Just under half on the gauge with no cooling fans
- City driving: First hash mark
- 70 mph freeway driving: halfway to first hash mark
About the car:
- New radiator
- Water wetter
- 16 PSI max boost
- 11.9 AFR on-boost
But if your DME never came out of closed loop, the car would run pretty rich at part throttle and idling conditions. I dont think this would ever be a problem with the car never warming up unless you were running your car in the winter with no thermostat or the DME sensor was bad.
I dont know what the temperature is in the block actually during this period because the thermostat is still closed during this period. On my digital gauge, the temperature comes up slowly but at a steady rate until about 90*F in the upper radiator hose. After this point, the temperature comes up fairly quickly to about 120-130*F when the thermostat opens.
It seems after installing a maf my car warms up (leans out) quicker. It used to take forever to reach 14s and now I see 13s pretty quickly. Maybe its the maf chips set differences.
The engine builder recommended 10W-30 because of the upgrading oil cooling system and tight clearances. He wanted a thinner oil that would flow better through the auxilary oil cooler in the fender well. He also pointed out that the manual was 25 years old and that oil technology has improved significantly. He adamently recommended against 20W-50 for this engine and the cool Seattle climate.
333pg333,
You should go over to Clark's and read up on seattles build. He's put LOTS of time and money into his car. I think I've followed it for something like 6 years. His engine should have like new tolerances. He can probably run a very light grade viscosity oil, compared to most.
I don't think it will affect his coolant temp, in a street application, but I suppose it could, marginally, on a hot summer track application.
Seattle's car is very trick indeed. I live in Maple Valley too and I am noticing my car running about the same temps and oil pressures he is, albeit on Redline 20W-50. Next change I am thinking of using 15W40 Redline.
Lou
Lou
