944 Tools
Doing belts, seals, pump etc. Where is the best and most cost effective place to buy some of the neccessary tools? I believe the flywheel lock is a neccesity, but I'm not sure about the pin wrench and roller wrench. How is everyone else doing it and has anyone come up with some inventive ideas to use alternatives to these tools?
Odd Posts
+1 on arnnworx. Bruce is a great person with whom to do business. and he is an active Rennlister
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Flywheel tool and the 'pin' wrench are a necessity, the roller wrench is nice but not a requirement.
A good seal puller is not a bad idea either.
If you are doing the front end seals there is about a 85% chance that you will need to replace the steel sleeves too - allmost always scored, if you don't replace then the new seal will fail shortly
