Sunroof delete
#61
Call me crazy, but "they've" been bonding valve stems to valves , turbine shafts like this for a long time now.
http://www.mtiwelding.com/friction-w...plications.cfm
If you really want some technology, ask me about Aluminum Valves that have all the properties of titanium.
Well, I could tell you but then I'd have to kill you.
#62
Friction welding is old... but only works on cylindrical parts that can be spun (like in a lathe).
That NASA post was about using a small rotating pin between two irregular shaped parts to achieve the same type of weld. (Friction welding is very strong, uniform, etc.)
But, yes... can you share details on aluminum valves?
#64
#65
Is this how they widen one piece cast wheels? I didn't think it was possible but I have been corrected. I would think that strength is the main issue when doing this so the Friction welding sounds a likely suspect. Is FW only applicable to certain metals/materials?
#66
The Impaler
#67
Making' progress! The guy doing my body work has done a nice job cleaning up my roof work. Rear fender looks good, too.
Should be painted this weekend.
![](http://www.ephotomotion.com/944/solid%20sunroof%206.jpg)
![](http://www.ephotomotion.com/944/ready%20for%20paint.jpg)
#70
Most likely I'll be driving the 996 April 6. Shoot - that's like 3 weeks away!
#73
Looks great! Now, you could've saved yerself the hassle and just bought yerself a factory sunroof delete car...like I did...
(Not a good picture. Plus, the car's dirty :P)
![](http://i150.photobucket.com/albums/s90/ausgeflippt951/DSC04445.jpg)
#74
Nice work Van. Look forward to the finished item. Good inspiration to do the same but looks like a bit of work. If I ever get a car caged though....
#75
Sorry Doug, no pictures of the inside yet.
Don't worry Voodoo, I've written a note to put on the steering wheel: "Don't Crash!"
