bypass factory O2
bypass factory O2
I'm sure it's been done, and probably well-documented...my searching skills are for ****. How hard is it to splice my wideband O2 directly to the factory harness in order to bypass the factory O2 sensor? Anybody got a write up on this? TIA.
I have hooked up the narrowband output of my LC-1 to the Input of the DME. You can't just wire the 02 sensor it has the wrong output and either 4 or 5 wires, while the stock 02 has 3 wires. As far as I know the wideband sensor should be located after the turbo and the stock one is located in the crossover, before the Turbo.
Small Business Partner
I thought some WBO2 sensors had 5-6 wires and packaged a narrowband and wideband sensor in the same housing:
http://wbo2.com/lsu/lsuworks.htm
If the WBO2 gauge/box/datalogger/whatever needs both signals for itself maybe you cannot just run the narrowband to the ECU and the wideband to the gauge. Otherwise one could wire the car up as stock with a LSU sensor in the bung and the factory harness to the wires for the heat and narrowband signal, and run the wideband outputs into the cabin. Then you could just connect to the wideband output for tuning when needed.
From that web page I could not be sure if the narrowband signal would be reliable with the WBO2 hooked up. It would be nice to have the option to leave the WB sensor in place and not always have to have a device outputting the NB signal for the ECU, like if you have several cars and would like to be able to hook up a WB meter in any one of them when the mood strikes you without having to swap sensors and fool with the wiring.
-Joel.
-Joel.
