WTB: adjustable front sway bar
I think you'd have to be able to make it at a fairly low cost. Though there will be interest, it will be primarily from racers, so their may not be a large market. my 0.02
It appears the choices are:
Kokeln
Weltmeister
or a custom unit like the route I'm going to go. As I mentioned earlier I'm going to use true racing components, which unfortunately are expensive. Parts alone will likely be north of $500. Kelly Moss used to make a similar setup and it went for well over $1000.
Kokeln
Weltmeister
Perhaps daigo and gt37vgt can explain the differences between their two suggestions?
diago chooses to use race brand blades and bars mounts etc rigged up similar to factory set up.
I choose a 4 rod ends 4 bolts some threaded bar from the engineering supply and a difference in geometry.
if you want something that looks more gucci get 2nd hand nascar 3 peice set up off ebay i might do that on the back
I don't really care what it looks like or where it comes from, so long as it works and doesn't weigh a ton. I've heard the Welts and Tarretts are heavy. I imagine a blade would be pretty heavy too, but even then so long as it helps you dial in the front end rather than having to make the rear compensate. I just want to dial in some turn in, so maybe you can fab me up one of these $100 specials.
well I think in a few months i will have a factory and I'd look at knock out a few set ups and spend a few days sorting out those rear ends but I'l explain how to dot it its pretty easy .
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Karl is finishing up the design of the blade type sway bar, he is fairly particular about the drop links.....No promise on time frame but I am hoping for a product for this season. I have been pushing him for a whle!
Chris,
I believe Karl was making something very similar to what I had in mind. I'm sure like everything else he does it will be well thought out.
GT37VGT
OK, I'm sure everyone here would love to have you show us how to do it for $100. Its all about new ideas
Badcoupe
I will take you up on your offer. I just have to figure out what the M030 front rate is.
Cheers
GT37VGT
Badcoupe
Cheers
