After 15 hrs labor - still have oil pressure issues
Hey Ben - did you just undo the electrical oil pressure sender and plug this in where that went? It is just so strange that it seems to act up at high revs after hard driving.
I have had an issue with my charging system ever since I got the car. On startup the guage reads low and the lights are dim. I have to rev the car to get the voltage meter to bump up. I've replaced the the alternator with two other used ones, tried two other starters, new voltage regulator, almost new positive and negative battery cables, brand new battery and still acts the same way. I am beginning to wonder if the new voltage regulator I got was any good.
Josh:
Try cleaning the grounds under the fuse panel on the drivers side. It is hard to get your body in there. I took my seat out so i could lay down and not get crippled!
Also clean the ground in the battery box that bolts to the firewall near the HVAC fans.
Drove home from work on back roads - about a 15 mile ride. Got the oil temp up to 200 degrees or so at the oil pan drain plug - probably didn't ever go over 4k revs. Oil pressure was fine - 4 or 5 bar at speed and no less than 2 bar at idle. Just so strange.....
P.S. Tim, I need to talk to you about turbo choices for a 3L build.
I never notice, anyway
+1 on the gauges - that's the first thing that came to my mind. Even if you have some oil flow problems, I don't see why your pressure would go down like that.
Hey dont worry about it.You caught me sleeping at the wheel
Previous to the problem , I had recently changed everything in the cooling system (I did it during the engine rebuild) so I was baffled. After running the car in my shop, and checking the temp of the hoses, nothing went over 140deg, but the gauge was pointed to the red zone.
A new sensor solved the problem.
