Gauge Panel FS
I need a spot to actually mount my wb02 gauge as its just kinda sitting there at the moment so I will be buying a new panel from lindsey racing ($34)
Here is a pic of it installed:
![](http://i55.photobucket.com/albums/g143/mikemarkota/1987%20Porsche%20944%20Turbo/ventednose006.jpg)
Someone wanna throw out an offer?
There should be two mounting points in both the lower left and lower right portions of the center console that the panel will affix to. You should have received screws. Is your panel from LR?
You can see the two screws in this picture of my set-up:
![](http://i98.photobucket.com/albums/l266/busabkickinbutt/DSC03771.jpg)
Yes mine is from LR, but there is nothing behind those screw holes - just air. What is behind your panel, specifically behind the screw holes?
There should be two plastic tabs with metal clips that screws screw into. These attach to the trim that holds your switches right in front of your shift lever, as well as the shift boot.
You can see the holes here:
![](http://dcauto1.gotdns.com/photos/0000/3535/94455211700.jpg?1209958273)
