968 door handle question and more
okk,
i remove the stock 944 door handle,
as you can see on the pics... the 944 micro switch is still there and a mechanism... i dont know how you call that
^ on the left side
3 questions
-the 944 micro switch goes on the 968 or not? or i use the 968 micro switch
- the mechanism, i remove the small pin of the 944 door handle, now i just have to put it back with the 968 door handle?
- finally, inside the door there is a little plastic thing, what is that, and what i do with it,.... i remove it..
is it this one whos going into the door?
off topic #1
i finished the install of rennbay lights and harness
off topic #2
what the part number or name of that small hose,,, its "slack" as you can see and need to be replace
thx everyone
^ on the left side
3 questions
off topic #1
off topic #2
thx everyone
do you think its better to get a package and change them all,
i assume none of my hoses were changed before...
but i know i really need to change the one on top..
okk,
3 questions
3 questions
- If you mean the small pin that holds the mechanism to the handle, yes, I 'think' you re-use it.
- I think you mean the white plastic thing that the arm attaches to. Need to use it!
HTH
