Rattle in the door panel?
I have a low idle so the car will shake at stop (working on fixing that). There is a loud rattle somewhere in the drivers side door panel? Before I try and pull it apart want to ask if anyone has any ideas. It will do it with the window up or down. Almost 100% sure it's not the window. Any suggestions?
Will
1989 Turbo
68K miles
NPB, FL
Will
1989 Turbo
68K miles
NPB, FL
I have the same thing, and found a few causes but its still there a bit when the door is shut. Have to look at it again.
The bottom screws on the window tracks were both lose on my car, the back one can be a bitch to get to (back being closest to the locks basically). There was something else too, I think it may have been a bracket for the lock mechanism was rattling.
I have seen several cases where the spot weld that holds the top of the rear track to the door frame breaks, this allows the track to make a nasty rattle. Easyest repair is to re-weld the joint.
Could be something as simple as a piece of change that fell down in the pocket, so before pulling the whole panel off make sure you check that if you haven't already.
