Procedure to pressure test exhaust?
Archives seach drew a blank.
Any standard way to pressure test the exhaust? I'd like to do this test over the winter just to confirm general health but haven't located a good description on how to perform? Is there one?
Short of there being one, I would think the process might look something like this:
- bolt a home made flange with air connection to end of cat converter/test pipe. Be sure to seal with gasket.
- pressurize exhaust with compressed air.
- listen for leaks; maybe use some soapy water to locate if needed.
Comments?
Some questions:
- Would you expect the exhaust to hold pressure similar to testing the intake track?
- What PSI would one apply to the exhaust?
- What would be the possible leak points? Wastegate area, dump return, hotside flanges, exhaust manifold - anything else?
Thanks!
Jeff
Comments?
Some questions:
Thanks!
Jeff
I'd put my hand over the tail pipe while it's running and listen for leaks.
You can also start it up on a lift and carefully feel around all joints for puffs of air.
I heard you can put a leaf blower on the tailpipe and blow air in and feel for air coming out. Beats burning your hands if you have someone else who can hold the blower while you feel around.
Great question Mike. Not sure really - sorta think I can hear a slight wooshing sound under the hood. Car generally holds boost, spools well on a 26/6. I have other reasons to be in that area and wanted to rule out any problems. Never seen anyone outline the test but seen it discussed before.
hally - My LR 3" leaks quite a bit on the slip fit from the wastegate. Would really like to find a way to seal it up. Any ideas. I like the leaf blower idea, I may give that one try.
The stock exhaust on my Audi. Had a type of header wrap at each joint. I'm gonna try that at each slip joint of the Lindsey exhaust. that should give the slip joint clamp something to compress.
What clamps are they using? I've found many of the 3" wide clamps don't fit tight enough. I've had good luck with the ones from Napa though. Just remember that once you use the clamp, you can't reuse it again. They stretch to fit around and seal up the joint and once removed, won't seal tight again. So if you've reused the clamps, replace them.
If you want reusable band clamps, look at the 1" wide Torca AccuSeal clamps. They don't span over the slip fit connection, but provide a tighter clamping force. These are all I use now.
To use the Wurth exhaust paste. you will have to take the slip joint apart, clean the parts that slide over each other, apply the paste, then reassemble. Kind of a PITA, but makes for a tight seal.
Another trick with the 3" wide band clamps is to take a 3" wide piece of aluminum foil, roll it up until it's about the diameter of a cigarette and slip it between the bolts on the clamp and the exhaust pipe. When you tighten the bolts, the foil will press against the pipe and create a tighter seal in that area. It works with limited success. Placement is key, and you want to roll it loosely so it will compress.
Quit Smokin'
to create positive pressure in the exhaust so leaks are easier to find, when the car is not running.
