Bad sad story time
Bad sad story time
Last night going home after work I felt my throttle give out. I coasted over to the side of the highway. Tried to restart it up a couple times, nothing. I jumped and looked at the engine seemed fined & checked under the car for leaks, And low and behold the stock cat pipe i had installed back for my emissions test was bright red
Car wouldn't start at all and had to get towed, boo
what do you think the damage is
how's the S2 short gear ratio tranny in a turbo??
I swapped the the s2 lsd transaxle into my turbo and like it. The difference is not huge, but it is there. 1st gear is a little short, but 2nd 3rd and 4th are nice. I don't drag race, so I don't care about 1st. The "big" 4th to 5th gap that people complain about is not really that noticeable. 5th is a good highway cruising gear; taller than if you just swapped the s2 r&p into the turbo trans.
