Steering shaft play ?
I've been making some changes & along the way I removed the dash. Now i'm reassembling. I've gone to an aftermarket steering wheel. The problem is that the steering shaft seems to have some movement in & out. You can actually see the output spline that the link to rack attaches to move in & out. I can't seem to find a grove for a clip or anything. does anyone know if there is a clip or ring that I am missing somewhere. I don't recall the movement before. Thanks..
The intermediate shaft that goes from the steering shaft to the rack has a pinch type bolt on each end. Is it the intermediate shaft with u-joints or the actual steering column that has play in it. The intermediate shaft is a PITA to replace...FYI
