stripped caster block mount
My car has been pulling to the right lately and i checked it once and figured it was my wheel bearings since there is play. I got under the car again last night and noticed both of my bolts came loose and one slightly bent. I bought new bolts and one nut effortlessly stripped out. Now what?
You likely didn't strip the nut but rather the nut came loose inside the frame rail. They were only tack-welded in place and the welds have been known to break.
I had one stripped years ago and my mechanic cut the frame rail, peeled it down, re-welded the nut then welded up the rail. It's held fine, but now I have a nut on the other rail that is loose and I'm not sure how I'm going to attack it.
If the nut is just stripped and still welded in a Timecert as Brian suggested would be easy. That nut doesn't see a lot of tension so a Timecert will be plenty strong enough.
My dialogue when installing caster blocks..."Godd***it go in there...No...YEAH, I got it..." followed by "F**K it is stripped!!!" and that is followed by a prybar being thrown across the garage.
