Upper Oil Return to Turbo
My mechanic has said he found my oil leak at this oil line. He said it's at the gasket and not the line itself. To to fix this oil leak, requires pulling off the intake because it's buried in there. My question is should i replace the oil line completely ($160 Dealer price) or change just the gasket? The leak is not pouring out but it is leaking .. i hope there is enough oil going into the turbo.
DIY, will take a bit of your afternoon...I wouldnt replace the entire hose if its fine personally...just be easy bending it around as it will start leaking.
Wait a minute......If it's a stock turbo the stock oil feed line doesn't have a gasket and uses a simple oil o-ring @ the turbo and a copper sealing ring at the banjo. If the line is stock, there shouldn't be any gaskets, copper or paper. Aftermarket turbo's can/may have different configurations but if it's the stock line the o-ring works fine.
Once the intake it's a simple fix.
Jeremy is wise. The copper washers can be found at any decent hardware store in the metric bolt section The o-ring is a high temp one, don't skimp on this. Cook some burgers, dip, beer, take the intake off before the game, at halftime, repair the leak and put the intake on after the game...we'll maybe the next day.
Same o-rings as stock so nothing special in the changing process. It should be a 2 to 3 hour job taking your sweet time. It's not uncommon for the upper ring to leak. Mine has been installed for five years now and it just started to drool. You're still getting plenty of oil to your turbo so don't sweat it too much.
Since you have a GT turbo you probably do have a metal lower gasket. Fun job getting to the lower. Since the gasket could just be compressed a bit, you may want to just try snugging the bolts up a 1/4 turn. The return's aren't under pressure so it's rare that they'll leak.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
