Axle / CV accident
Hi Guys,
nothing EVER seems to go right when I work on the car (guess its inexperience) Went to fit a new CV boot tonight and taking the axle out I managed to trap my finger and in the process let go fg the axle. As I had already removed the circlip it fell to the floor, and the bearings plus inner and out race scattered across the garage floor
so I set about rebuilding it. My first attempt resulted in the outer sheath (the big metal housing which the 6 cheesehead bolts go through) not being able to rotate. I presumed I had something back to front so I reversed it. Now it works fine and has plenty of free movement. (as it should) I took it for a test drive and everything seems fine even when I light the wheels up in a tight turn
Is it possible to put it back together incorrectly (if it has all the movement it should?)
it got to the point where I refussed to give in. I am sure the language flying in the garage was not for public consumption. In the end it was quite easy!!!!!...............................................just took me 1 hour to realize
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Congrats - sounds like you did it OK. I remember having a similar experience with my 914 about 13 years ago... All of a sudden: plink, plink, plob, bing. And thinking, "well, I guess I'm gonna learn something new today!"
What you probably did the 1st time was get the relationship of the grooves on the inner and outer pieces out of phase... The second time, you did it so the joint could move and the ***** would travel down the grooves.
Are you going to Watkins Glen Oct. 15 & 16?
Hi Guys,
