Location of ground straps?
Hi,
Trying to hone in on the exact location of the engine ground straps. From the picture in the manual, they look like they are next to the speed and reference sensors.
Is this correct?
Is it possible to see both the ECU and block to chassis strap when you look down the firewall?
I think I can see the ECU strap from the top but I don't see to see the engine to chassis strap. Wondering if it's hidden or maybe missing.
Thanks!
Jeff
Is this correct?
Thanks!
Jeff
Hi,
Is this correct?
Thanks!
Jeff
Is this correct?
Thanks!
Jeff
OK. I should be able to follow from the battery cable to the engine to locate the attachment point. I would expect the DME ground to next to it.
