does vitesse piggyback work on vista ?
bought the rennbay wiring harness and e-code h4 upgrade. Then bought from xtralights.com the Xetronic Digital Lighting System - H4 Type
4300K (Crystal White - Factory/OEM HID Color) High & Low Beam Xenon (Bi-Xenon). Just like it came from the factory other than finding a place to mount supporting hardware.
For VISTA:
Install the software on VISTA (Fresh installation). You might get a single error about a acrobat module not able to register, ignore it.
After the installation is complete, go to the directory where you installed the software. "C:\Program Files\VitesseR"
- Right Click on the executable file and select "Properties".
- click on the "Compatibility" tab and click on "Run this program in compatibility mode for:"
select "Windows XP (Service Pack 2)"
- select "Run this program as an administrator" under "Privilege Level"
- Click "OK" to apply the changes.
This should take care of it.
Thanks for this rluciano. IT WORKS !!!
John, Ive been extremely busy lately and not responded to your email. Sorry for this. I am sure I will need your advice on some PB tips in order to properly adjust my car.
Thanks the lot guys
For VISTA:
I've been trying for some time but I never got past loading the security lock file. It always tells me to select from another directory! Do you know what I'm talking about?
Sprint.
READ the "README now" instructions on the CD. You need to copy files from the CD to the VitesseR directory.
