alu flywheel, is it worth the money?
I am considering to buy aluminum flywheel.. does anybody here has one installed and can tell if it makes a big difference on 951 or not..
I have one on my car. When it was installed a lot of other work was done at the same time so it is hard to isolate its impact. I think it probably had a small impact. The car was unchanged from a driveability impact.
I have chosen a lightened crank and lighted steel fly wheel . but An aluminum flywheel doesn't require removing the crank . i think its hard to justify its expense as a stand alone operation but if your doing a clutch it might make sense
Personally, if you have a guy like Markus Blazak do the work, the lightened steel is better to me. my 0.02
Again, really not worth it unless your cars sees a lot of trackwork. The combo of lighter stuff has a tendency to want to stall on the road btw.
FWIW, I had my stock flywheel lightened to 9.5# by Marcus. I like it a lot. I went with the KEP I pp too, which is also lighter than stock. It's not too light so as to be annoying around town - I can still 'cruise' lazily with no problems - but it is definitely noticeable. In a good way IMHO. I had to replace the clutch, so I went ahead with all this at the time. I wouldn't do it just to do it ... but if I'd do it again if I was 'in there'.
A lightened fly wheel is no big deal on a street car. It barely makes a difference for drivability, but, does rev up/down a little faster and feels good. If you can't rev up the car and find that you are stalling it, practice a little in your neighbourhood until you get the feel of it. Maybe I'm a super-star (doubt that! ;-)), but, I went from stock to lightweight PP and Flywheel and it didn't feel any different for clutching.
i had a light weight flywheel(fidenza) in my 86 track car and yes there is a big difference in the way your revs will drop off.for a street car i would not recommend it unless you are into heel toeing all the time
I have to agree with Jason. I have a lightened crank, aluminum flywheel and lightweight clutch and the car has lost little drivability. I can't remember ever stalling the car in traffic.
Rennlist Junkie Forever
The answer is "yes".
It's always worth it. No matter the use of the car (in the case of of the 951).
The reciprocating mass is ridiculously heavy, coupled with a restricted exhaust, and heavy balance shafts to sling around,..... and you end up with exactly what you have.... an engine that revs like it is buried in molasses.
These engines really benefit from a lightened flywheel/pressure plate. And if you're lightening the reciprocating mass... light weight rods/pistons/crank.
It's almost impossible to take too much weight out of the reciprocating mass of these engines.
But once you lighten up the engine, it starts to behave like a N/A setup with respect to throttle response, which is all good.
TonyG
TonyG
Well I do that in traffic anyway, so no biggie.
I'm with Tony on this one -- these cars (particularly the turbo) rev painfully slowly. So what -- you've gotta give the car a couple more revs to get her goin...have you not ridden a crotch-rocket?
Personal preference.
LW flywheel & clutch on a street 951 is okay and not significantly noticeable from a drivability standpoint. You tend to slip the clutch a bit more but don't have to really think about doing it. A LW FW, clutch & crank is a bit too much and the lost inertia is noticeable on the street (to me).
actually I have a chipped 951S engine with complete transaxle, brakes and everything that goes with it in my garage, waiting for me to swap it all to my na beauty (which died one week ago. cluch together with flywheel somehow got loose from the engine.. I have yet to discover how)
I wil first reseal everything on 951 engine, than I would like to optimize it as much as possible before puting it in the car. I was considering the 340hp lindsey pack, but at the moment I cannot afford it, so maybe aluminum flywheel, ceramic clutch and maybe new injectors.. :|
if you have an idea what else could I do with the engine now that its out, it is welcome
btw: I will stay on manual rack, but will upgrade to aircon (my 944 is w/o one)
I will not use the car on a track since I live in a country with 2 million people and there is not a single official track in slovenia. If I'd want to track her, I'd have to go to grobnik and that is in neighbor country - croatia. what a ****ed up country this is. maybe that's why so many people die on the road every year here.
