Sloppy Steering
1 Post
Sloppy Steering
I must say the steering in my 951 has gone from okay, to 1940's dump trunk in the past six months. I've replaced the tires and the dampers aren't bad so I'm left with trying to figure out whether the control arms are bad or something in the steering is bad.
The clearest symptom is that the car follows grooves in the road and I have to correct it continually on rough surfaces. Also, the more off-center you move the steering, the harder it is to turn the wheels (while rolling).
If you jack the car up and turn the steering, the wheels turn with even the slightest movement of the steering wheel. Of course, under-load it may all be different and a few mm's of slack could translate into 1940's truck handling (i'm no expert on that though)
There are no noises indicative of loose anything.
My gut feeling is steering rack? (No leaks, rubber boots are perfect). I'm trying to picture the suspension geometry in my head. To me, if the conrol arms aren't worn, then the only thing left that would allow the wheels to move would be the steering linkage/rack.
What do you guy's think?
Check the U-joints in the steering intermediate shaft. This is the shaft which connects the steering wheel to the steering rack - these joints will wear out over time and can cause some play in the steering wheel.
Other things to check include tie rods, suspension bushings (I'm sure the control arms are fine, but the bushings or ball joints may be shot), wheel bearings and even the alignment.
I think Scott nailed it. First check tie rod ends and wheel bearings as they're easy.
IIRC a bolt holds the steering shaft U-joint together. It could be loose.
