Brakes, Brakes, Brakes.....
#61
When reviewing data during braking/it is common to see a decrease in brake pressure when blipping the throttle. When you get a chance to dig into your Motec data you will be amazed at the detail you will get.
#62
FWIW, the pedal in my car is on the soft side too. New MC, multiple bleedings, fresh SRF, tons of cooling and well-adjusted bearings have't been able to firm it up. Drives me crazy that I can't nail the problem. The car is PCA Stock, so stock TurboS brakes.
#63
Right, I figured that's what you meant. This is indeed one of the main attractions of the upcoming data. To learn and continue to do so. I like the challenge and it's exciting to think that there is always improvement to me, not just the car.
Tony, what rotors are you running? I found that even though the pedal could be on the soft side from time to time, the slotted rotors really seemed to help overall. That's more fade than soft pedal but worth a try if you can get a hold of some.
#64
#65
Good luck in finding the cause. It's not an uncommon symptom of these cars. Be interested to find out if there was a failure of a particular component such as the booster reservoir on a semi regular basis that was the common fault.
