injectors
injectors
I have som injectors that suppose to be Siemens 55# , but they look totaly different from the ones I allredy got . They have the number 8305 and 17113841 .. anyone knows.. ?
Yes it seems like the Siemens are 2,5ohm ..Always thought they where 3 ... Well anyway took my siemens to a injector service workshop today and The guy there says that most likely they where running with too high duty cycle. hmm .. According to most people here @ the list that may not be the case as they should support 350rwhp .. But then again I`m not sure about engine output since last mods.. bet it`s not near 350 yet..
Well .. official 16psi, ( but it`s usually set to 18 .. sorry John ) . Vitesse stage II w/ wasted spark, SFR stage II headers, 3" LR exhasut with Borla muffler, Tial 38 WG, light headwork .. just some basic that is.
Other than that I have the Zetronisk WBO , knock sense and 4ch EGT probes..
Measure it. You can buy a kit or use a dwell meter.
http://www.impconcepts.com/fuelinjec...torforsale.htm
http://www.gassavers.org/showthread.php?t=7714
I've used them for 3.5 years...no resistors either. I think that Vitesse recommends 72's for the OP's set-up, if I remember correctly. I just inquired a few weeks ago about the same (similiar) set-up, and I think John said 72...let me check e-mail.
EDIT: Vitesse recommended 72's if I also use a larger turbo.
