Can someone help me diagnose this idle problem
look at the video, the motor starts to want to die then the mass air flow sensor make a noise
also, the clutch is making noise
http://s271.photobucket.com/albums/j...t=P1090595.flv
Sounds like your idle speed valve is gunked up. Try removing it (kinds hard since it is under the intake manifold) and spraying the inside of the valve with throttle body cleaner.
