NOT the DME! Headlight, fuse issue... read new thread.
I was at the DME, spliced into a solid thick green wire to get a reading on the voltage... car won't start. It cranks, just won't fire up.
I diden't even cut the wire or go past the outside shield wire... hmmmm
My question: Does that outside wire have to be there?
When i get her fired up and a new TPS installed... It is for sale for anything I can get.
Odd Posts
What gauge?
And after all the work that you have been doing, can I suggest that you get that car running and just drive it for a while? You will remember why it is such a pleasure to own a 951 and will likely reconsider selling.
It was getting dark, so I didn't have alot of time to try and fix it.
I hear a clicking noise comming from inside the DME when I try and start her
No, I just spliced it to get a reading for volts. never connected anything to it.
I crank the key and she won't fire up all of a sudden.. Bizzarre. I hear a "click" from the DME when I turn the key.
I appreciate all the help, lets get this last project finished.. then off to ebay, craigslist, and the autotrader.
I appreciate all the help, lets get this last project finished.. then off to ebay, craigslist, and the autotrader.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Did you experience a no-start issue aswell?
I tried taping the small scrape, but she wouldent fire up.
I will try to sort everything out in the morning, I'll post some pictures, and a video of whats going on. Thank you, and please check back!
-Mark
-Mark
I experience a no start because my DME relay chose to die at the same time. I think what I ended up doing was pulling the wires apart even more so there was enough slack to install butt connectors or solder in a new run of wiring.
Might be worth it to clean the contacts or just replace your dme relay btw.
