fastest stealth closest to stock?
The printer was broken for the dynojet but they gave me all my run files and I downloaded the dynojet winpep software, I can't get it to find the torque but the max rwhp today was 328.61 at 18psi
94.77'F 29.97in-hg, humuduty: 14%
Some parts that helped make things possible today:
gt3076r
40mm Synapse
LR stage 1 IC
Vitesse PB+MAF+V-FLEX
Zeitronix wideband
Thanks to those that helped make things work out:
Andrew
Vic
Derek
My self
Tonight going to see what I can do on the 1/4 mile and track time september 8th and 9th
gt3076r
40mm Synapse
LR stage 1 IC
Zeitronix wideband
Andrew
Vic
Derek
My self
I had a good time at the dyno today. Glad we were able to repair the maf wiring and continue with the fun stuff
Better install some wider tires in the back, Jason!!
Was new and hard to control the torque also the master or slave cylinder for the clutch is dying and caused some bad miss shifts. I think I damaged my pressure plate and now my tranny whine is worse. So it was depressing and realllllllly exciting and fun. Although I did not make 12.9 like i did with previous set up I did make 13.3. I need 245 in back =D. The car flys especially when it catches the ground. =P
Ran into a white s2 =)
Redline: 6800-7000 Final drive didn't count as we ran out of time still trying to master the ebc and it's learning capabilities as the day was over the afr was spot on but figured would just work on the ebc on the highway. Sooo the rwhp could be higher but won't know as I ran out of time and money...
His redlne is 6800 but the engine will stop acceleratng at 6700-6800, so his top in 4th is around 123.7 MPH.....trust me.
Excellent results, BTW.
ST, do you see any correlation between final drive and dyno results?
So I wonder now, is this the highest rwhp stealth closest to stock with ought deleting anything and swapping the afm for a stealth maf?
Looks good Jason. Maybe your Winpep software just needs to be re-installed. If you want to e-mail me the file I'll see if mine will show TQ and post it if so.
Here it is-there's definitely something wrong with the file. The text says 321 HP and 331.8 TQ with SAE correction, but with the TQ graph looking like that who knows. If I show RPM instead of MPH, it gets even worse.
