Front Clubsport Wheels And Other 951 Stuff FS
I have four front clubsport wheels (7" x 16") for sale. Two of them have been polished and clear coated. The other two are standard OEM finish. All are in good shape. Will sell for $150US each o.b.o. plus shipping. Includes center caps. Will try to post photos later.
I've got lots of other stuff on shelves in my garage, will have to post photos and come up with some prices. Tons of stuff - stock catalyst 951 exhaust, ported bare head (8.3:1), valve springs and retainers, cam housing w/ cam, Garrett T04E 60 trim compressor housing, Bosch afpr, stock injectors, adjustable Forge recirc valve, stock M030 springs and t-bars, 500# and 550# 2.25" springs (the 500's were on front of Bilstein Escort Cups, 550's were on rear), full set of Kumho V700 (V70A) autocross tires 225-50/16, 245-45/16 (excellent condition, only used for 2 autocrosses), used oxygen sensors, set of used 100.00mm and 100.50mm Mahle pistons, good core shortblock, stock flywheel, PIAA "Super Plasma" H4 headlight bulbs, used Alpine cd player deck, multiple size silicone hose for i/c pipes etc, used MAF sensor (76mm C&L sensor w/ 30# calibration tube - equates to approx. 60# injectors for our 4 cylinder cars (I used w/ 52# injectors) - modified w/ hole for stock AFM AIT sensor), used K&N filter for MAF, 951MAX MAF chips, various pipes and clamps, battery ground strap, two engine wiring harness being used for donor plug ends, almost new MSD Blaster 2 coil, used TPS, ISV, OEM front brake cooling scoops, brake pad sensors, Turbo S front upper strut mounts, OEM leather non-airbag steering wheel, etc....
Am also looking for a few things - good condition OEM jack and handle, good condition black center armrest lid, fiberglass hood, lexan rear hatch.
I'll try to post some photos of all the stuff I have, and will think about appropriate prices for everything.
Caster951 - I sent you a pm regarding the jack and console lid
Modded - the TPS is almost new, but is missing the little o-ring from the back. Not sure where it's gone to, but you can swap out the one from your existing TPS. Paragon sells them new for $112. I'd sell mine for $60 plus shipping.
Colt45 - yes, this is the full center section of exhaust. One end bolts to the bottom of the turbo downpipe, other end connects to the rear section of exhaust w/ muffler. The exhaust is in excellent condition. It includes the factory catalytic converter, plus the mini cat for the wastegate. I'm not really sure what it's worth, how about $80 plus shipping? Shipping might cost a bit, it's a pretty bulky piece. May be not too bad if ship Greyhound or something like that.
The Forge valve is their "Type RS" unit, sells for $230. This one is essentially new. It's pretty trick - has a **** on the top for adjusting spring tension. It's got a bolt-on fitting on the bottom that works with a Gen1 Eagle Talon, although Forge does sell different fittings. It didn't work great for me, and I went back to using a crushed Talon valve. It would be a bit of a pain getting it to fit on a 951 unless you have a custom i/c pipe w/ the recirc valve on the left side. I should probably have left it off the list for now, and try to sell it to a Gen1 Talon owner. I'll try to inventory what silicone hose I have, and post a photo.
