Throw out bearing
Jane Bond 007
Throw out bearing
Well, I borrowed a borescope and figured out that the throw out bearing came apart. I am NOT a happy camper. I figure that since I have to do all of the work of clutch job, I'd like to install a 968 bell housing to make future jobs much easier. Is this possible? Does anyone have a spare one? TIA
https://rennlist.com/forums/showthre...ht=CLUTCH+FORK
The 968 bellhousing is a different length. (longer I believe) You can get everything to line up properly if you also use a 968 torque tube. I didn't do any further investigating after finding out it's not a bolt on affair due to lenght, but other issues you might run into are starter and slave cylinder locations due to the 968 having that funky dual mass flywheel setup.
You could save that X-mas bonus, get the bellhousing, torque tube, AND 6 spd tranny - then you're set. It's easy to spend other peoples money.
Did the TO bearing come apart or did the thrust washer come off and the C clip is lying in the bottom of the housing? If the latter, see how the washer is facing when it comes apart.
Jane Bond 007
Thanx guys. I"ll know more when I get it all apart. I just went out to get a transmission jack since the jig I made finally gave up the ghost. I'll try yo get it apart this weekend to see what I need to get from Jason.
