Will these wheels fit an 86 turbo?
Will these wheels straight up fit my 86 turbo?
Fronts:
5x130
17x8.5
Spacing inside the wheel: 5 3/4 inches
Rears:
5x130
17x10
Spacing inside the wheel: 6 inches
Fronts:
5x130
17x8.5
Rears:
5x130
17x10
Jane Bond 007
Offsets are usually measured in mm. If there is a number stamped on the back preceded by "et", that will tell you your offset. The early offset is 23.3mm. I have a set of Speedlines with a et25 that is 18X10. It has a 7" inner hoop. HTH
