GURU CHIPS F/S
I have a set of GURU Racing chips i just removed from my 87 951 they are KLR v1.0 and DME v7a..they came out of a running track car the only reason they were removed was i installed a Lindsey Racing 340 rwhp kit and they use there own chips....they are 24 pin if that helps ....Best Offer...
Hey Man
Good luck and nothing personal but selling used Guru chips is like comping free coupons for a root canal. WOT they usually worked great, anything else they were problematic to say the least and the support stream is old history. I have a full Guru Link AFM MAP setup with hand held programmer and doubt if I could sell them even though some people are able to tune out issues given enough patience. As far as value...I would say $30 tops.
I would have to disagree, I have a set that came with the car, and for two years the car has ran great. I am working out kinks in my Innovate WB install. But when it was running I was seeing 14.7 give or take at idle and off boost. Under boost it ran in the 11s. I plan to upgrade to SFR MAF w/ split second Fuel computer. I may switch to Maxtronic, if i cant get the chips to work w/MAF and Turbo upgrade.
Steve
I would like to get some dyno numbers before the switch, but there are none local, and not that important to me as long as the car feels responsive.
Steve
