Post Head Gasket Install Woes; help please!
My head gasket went about 3 months ago. Finally got it over and had a widefire put in, but now am encountering a couple of conditions.
At operating temp, she still is barfing out white smoke of the exhaust; thought this could still be coolant inside, but seems strange.- Update- just spoke with the shop, smoke is getting better- the cat must've been full.
Additionally, stock boost readings at idle are at about 12, and oil pressure at idle is pegged at 5- do I have a plugged oil return line to the turbo?- Maybe just need to readjust the boost post the head gasket change- it seems to be shaking and shuddering a little at this point.
Any help you can provide would be great; my baby is hurt!
Thanks in advance.
Nate
Thanks in advance.
Nate
Hey Man
Are you saying you are seeing 12 psi at idle? Impossible. Was any head work done when the HG was replaced? I might have this backwards but oil pressure pegged at 5 could be the wires are crossed at the sender; if it reads 0 the ground wire at the sender is disconected.
yeah, if wires are crossed at the sender it will do as you desribe.
If you are seeing 12 in/hg at idle, you have a vacuum leak somewhere. Should be running a little rich or idle a little off if that's the case too.
I'm with Spidey, 12 in/hg (vacuum) at idle would indicate that you probably have a vacuum leak, which is causing your rough idle. At sea levl the consensus seems to be that it should be more like 15-17 in/hg at idle. (Up here at 5k feet I'm pretty happy with 12...)
In my experience, the easiest way to track down a leak is to pressurize the intake tract using a boost system tester. Here's a link to the Arnnworx tool or you can fabricate your own from some a PVC end cap and a schraeder valve.
