Turbocharger (Turbine) Outlet Stud Size?
TRB0 GUY
I'm at work, trying to order a set of exhaust studs for the turbine outlet and can't remember the size. I remember that they're M10, and the pipe side is about 40mm long... but I don't know the turbine side, nor the thread pitch. Anyone happen to know what they are off the top of their head? M10-1.25? M10-1.5? 40mm length?
TIA,
Kevin
TIA,
Kevin
Last edited by FSAEracer03; 07-23-2008 at 12:51 PM. Reason: I shouldn't post before my morning coffee
Hey Man
Not sure, it's the length as listed in the parts description. I think it would be only the exposed length for the nut and not the entire stud. I bet Paragon can tell you for sure.
