Dyno’d 2 Cars: Need Help Finding Non-Boost (?) related Power Loss
#31
Excessive advance per load on a given setup will result in reduced power with factory DME.
If this car is more efficient around the torque peak area, it won't recover by the end of a dyno run.
I would now put the APE chip into the weak car and dyno, and change nothing else, but that's just me.
#32
While the smooth torque curve might be an indication that since the timing is already retarded, the KLR/DME does not need to make any adjustments since the peak cylinder pressures are lower and not causing any type of knocking. Sounds like an important clue in the puzzle.
#33
Another thought, I know you said you have swapped just about everything, but.... Is it possible that you have reused the cam tower? I mean, if you have a couple of bad lobes on the cam, it might be just enough to cause reduced lift, or maybe a few bad lifters, or maybe even bad valve springs. Also problems like these might, just might, cause enough noise to confuse the KLR/DME to think they are knocking noises and cause it to pull timing. Of course this is just a SWAG (swinging wild *** guess).
