6 speed conversion
6 speed conversion
did the search thing and didnt find too much so some help would be good. I have an 1987 944 turbo and i found a 6 speed tranny, my question is whats involved in the swap?? From what i know the tranny fits in perfectly the only thing is that the speedo is a no go. You have to get a 968 abs module and a g16 relay but then what do you do??? Any write ups around or any pros who can give me some guidance??? BTW my car does have ABS
reflexr (10-04-2020)
I have a 968 6-speed LSD in my 86 951. The work was done by a local mechanic. The most difficult part was the speedometer. It required a bit of fabrication. For some reason, the speedo is only accurate below 80 mph.
Most Audi versions of 01E transmissions has a similar speedo pickup like original 951 transmission has. These parts can be installed into 968 trans as well, so no hassle with ABS etc. Audi used same basic trans at least in A8 & A6 models. Might be little bit difficult to find these Audi units in the states because most of your cars are automatics. It's totally different story in europe.
It is at least as durable as a 951 tranny. Some 6-speeds were made with a factory faulty pinion bearing (too tight) which can grenade itself, but it will make lots of noise to warn you before. And most of them have been fixed by now.
Does anyone with a 6-speed 951 experience any rattling or noises after the conversion? I've been told the 6-speed doesn't like single-mass flywheels and I want more data on that.
Its not the transmission that is causing this vibration or rattling its the particular cars setup! If you install a single mass lightweight flywheel in a engine that was designed to have a 25lb heavier flywheel that uses harmonic dampening then of course your going to have mismatched components and thus some sort of after-affects!
The 968 transaxle is based on a G50 design and uses most of the same parts, these transaxles are far superior to the earlier Audi 5 speed design found in the 944 line!
