Initial E85 Results
The GM sensor part # 12570260 but is $350-500 depending where you get it from. I have heard of a cheaper version under $75, part # 12568450 but it's been discontinued by GM for the more expensive one(of course).
I looked into this a few months back. The resonably priced sensor would have cost in $350+ range (when purchased in quantity). However, I'm told that the sensors are not very accurate. On a NA car, you will get away with it, but on hi-performance turbo car, you will get in trouble. From what I noticed, most Flex-Fuel engines are NA not turbo.
Initially, I wanted to run a E85 sensor, feed the input to the DME and let it handle the blend. However, due to the cost of the sensor and the questionable accuracy, I opted to leave it alone for now. I think it's reasonable to expect a 951 owner to decide on the fuel he/she runs and select the mapping accordingly. I expect, 951 owners in areas where E85 is readily available, will use E85 most of the time.
This is what I found out. I have a contact @ GM, I'm hoping to get a sensor to try. The less expensive sensor was a old version, someone snatched a good quantity, haven't seen any on the market.
I forgot to mention another important property of E85 that hasn't been discussed.
As I work in work in Boulder, many of the places where I go for lunch have special parking places for alternative fuel vehicles/hybrids.
I love taking a parking spot from a Prius!!!!
-Dana
-Dana
I'm in the process of setting my car up and testing on it. Some initial tests I ran with E85 were amazing! If I had control of my timing and a more tuneable MAP, I have no doubt I would see some surprising numbers with the amount of boost I'm running....or more importantly the amount of boost I want to run.
There are a few E85 stations within a couple miles of me so I will completely switch over once I get everything straightened out and post the results.
John, I'm also keeping an eye on your V-Flex E85 solution.
The V-FLEX E85 will be a continuing development process. There are many variables that are still unknown. The Ethanol Blend %, summer vs. winter blend, different parts of the country or ROW??
The sensor would be great. I am little lucky as E85 is available near where I work and about 10 miles from where I live. I can get E85, but one must strategically plan fueling. Sometimes its just not available and ratios aren't available.
The GM sensor, from what I understand, measures both alcohol content and fuel temp. It outputs a sqaure wave signal with the frequency giving the % alcohol and the amplitude giving the fuel temp. The ghetto method for determining fueling requirements would be to fuel up, drive for 10 minutes to get the fuel in the sensor, measure the frequency of the sensor output with a DMM or spectra analysis tool, and then adjust fuel pressure up or down (assuming not too much changed) based upon the mixture of gas to E85.
-Dana
-Dana
Using a E85 or fuel composition sensor will be great. However adapting it to earlier cars, such as the 951, will be a challenge. When everything is working fine, no problem. However when the sensor fails (and it will), how do we alarm the driver? On OBD2 cars, CEL will come on. On our cars, something must be developed which will be expensive on per unit basis.
I think leaving the decision of what fuel is used to the driver is more reasonable, at least for now.
GM and other car manufacturers prefer to use a sensor because when speaking on the average consumer, leaving the decision of what fuel is used up to the driver, is generally not a good idea. lol. I expect everyone here would care more what goes into the tank and know before hand what it is.
All I would want is a switch to change over to normal gas if I ended up somewhere that didn't have an E85 station close by. I ahve ruled out doing this currently as it would be a nightmare with my Link to redo tune all the cells to switch between E85 and standard fuel (0-10%). I'd have to pull out the spreadsheet and go through and change each cell when I wanted to change fuel.
With the V-FLEX, you select (via a external switch) the type of fuel you want to run. The DME does the rest for you.
Just swap out any old rubber in the fuel system and the fuel filter. That's about it. Then just need to tune it for the extra fuel and fill up the tank. You should change the fuel filter again after a couple short runs also.
Chris White, this is correct right?
Thanks,
George
I have the 1000's (injectors) now for my projected 425whp. You may want to go to the next step up, which is to 1600's. They work great in honda's where they have a true sequential firing order. Do you have a Cam sync sensor for your Tech3 that will allow sequential firing of the injectors? If not, maybe stick to the 1000's.
E-85 only car. I have about 20 stations to choose from! And I truly won't be drivin this car to anything other than dedicated events or get-togethers.
You should change your new fuel filter shortly after installation because the E-85 will clean off the leftover varsol/petrolium film from the Gas tank liner. That stuff tends to clog the filter. After it cleans itself out. just change the fuel filter as normal.
I would change out any old rubber lines and forget it about them for a couple of years. Change out again then.
If you are going to change things, why bother with rubber fuel lines? Just make up a replacement set using teflon braded lines and AN fittings. Nothing you put into an engine will eat the teflon lines. I changed over when I started using toululene.
