Re-usable copper gaskets
![](http://members.home.nl/porsche944turbo/images/gasket.jpg)
What part of these gaskets is re-usable?
Perhaps they are re-usable, but not as a gasket for the headers to the x-over!
Did I do something wrong?
Am I the first to whom this happens?
They where on the car for about 6000 miles.
The copper gasket at the turbo downpipe is in perfect condition.
I did not have to pry them of. It seems like they where mounted under some kind of tension.
UAE Rennlist Ambassador
If those are the LR copper gaskets for the headers to x-over, then they worked fine for me for 1 year and about 12,000kms.
When i got some good used headers locally, they did not fit, and i use the factory crush rings (whiched did the job), thus indicated to me that if anyone has a problem with a leaky exhaust and use those gaskets as a "fix", that means there is something wrong with you're exhaust.
Using them to be "re-usable" is a different story, and i have one for the turbo down-pipe to test pipe and also lasted (and still on the car), but that one if from Fabspeed not LR.
Maybe you're EGT's are a bit high? since we know copper expands faster than aluminum or steel and caused what you experienced?
You might be right on the high EGT's. I was seeing 950 celcius. The exhaust headers are wrapped so the temps at the connection to the x-over will be higher then unwrapped.
