thanks guys, i want to keep as much stock structure there as possible and both the fittings i found and your solutions would work and still let me keep the intake support bracket...
but i was going to have to put basically move the intake support from the front of the mount to the rear using a long set screw through the intake support with a locknut on the back...
then i was going to have to modify the sensor for the connector...
i found a local fabricator willing to do the dissimilar metal weld for less then i spend on any two fittings and i put the -8an flare fitting on the bottom on my tube....
