Innovative LM1 set up/calibration?
Old 06-11-2008 | 02:50 PM
toddk911's Avatar
toddk911
Drive-by provocation guy
Question Innovative LM1 set up/calibration?
Is it necessary to wire in the LED and go through the whole calibration like instructed???
And do re calibrations in the future????
Old 06-11-2008 | 03:01 PM
DrZ1's Avatar
DrZ1
Only if you want accurate A/F readings.
Steve
Old 06-11-2008 | 04:19 PM
Dave951's Avatar
Dave951
Calibrations are key reliable reading as DrZ1 said. The accuracy of the Innovative setups are what make them desirable, which can be partially attributed to the ability to re-calibrate the sensor as it wears. In short this a NECESSARY step.
Old 06-11-2008 | 07:05 PM
95ONE's Avatar
95ONE
The LM-1. doesn't need the light. The LC-1 does so you know what part of the calibration its going through.
I just twisted a 12v LED to the necessary wire and touched it to any old ground while it calibrated. when it tas done.. I quickly un-twisted the LED, taped off the wire and zip tied it back. Shouldn't need it again for months.
Old 06-11-2008 | 07:22 PM
MM951's Avatar
MM951
On my LC-1 I hooked it up.. might as well take advantage of all functions. If you have that metal gauge holder under the radio its easy to drill a tiny hole and mount it there
Quick Reply: Innovative LM1 set up/calibration?
