balance shaft gear removal
Is the balance shaft gear supposed to just pull off after the 24mm bolt is removed? I cant get this thing out no matter what, and there is no room to use a gear puller.
According to clarks garage:
Remove the crankshaft pulley bolt using a 24mm or 15/16" deep socket. Remove the power steering pulley. Remove the alternator/AC pulley and balance belt gear as a unit from the crankshaft.
I'd offer to help you out but I'm in Philly till Friday.
What kind/size gear puller does one need to get this thing off? I'm trying at the moment... Also need to get the gear wheel(s) off for the balance shaft driving mechanism.
So I wager I would need 2 gear puller sizes...
Porsche-noob-91 (01-11-2023)
