Moton installation
#46
Yup, I had to cut the drop link bolt in half basically and needed to thread it further down with a die.
I used a small piece of rubber between the washer and arm instead of the bushing. It works fine and clears without any issues.
#47
Moton must have changed the design in the last years, as the connections to the canister lines on mine are +-90° towards the front of the strut.
For the fortune they sell their products for, Moton could at least provide parts that fit without having to perform such ridiculous butchering
![nono](https://rennlist.com/forums/graemlins/nono.gif)
#48
I talked to Lex at Moton and Karl at Racer's Edge. This is a phenomenon that affects all early (short) arm 944's now since Moton only makes the strut body with the line swivel on the inboard position. Moton can make you a custom body with the swivels oriented forward or aft but it takes a special request. I am have just finished cutting down my links and will use the rubber grommet below the arm only and just a body washer on top. Karl thinks this is the way to go. I also talked to Markus Blaszak (since I am using his arms) and he suggested fabbing a special link which he is going to email me a diagram of.
#49
Any more pics, news, info, hints etc on these installations?
What springs are you all running?
