Knock - where to look first
Trust me, you will know. The bearings will be very loose in the housing. Mine fell out when I took the axle out. Used the bearings in my son's wrist rocket (slingshot)
Honestly, you should replace both axles. You probably have many miles on them and they are a wear item, long wearing one, but they do require replacement. Both axles from a good source is around $300. If you need a lead to a good OE supplier, PM me. Don't get the aftermarket axles, OE only.
George
George
Also, when you put pressure on the axle, do you see it moving up and down in the boot? How loose is it? I don't want you to go through this effort when it's not your axle.
