PS pulley (on crank) came off... AC pulley (on crank) wobbles... gauge now shows no
No problem; I recently read instructions that said to put on the PS pulley, torque the 24 mm bolt and then to put on the AC pulley with the four little bolts. That can't be right on my car (AC pulley wouldn't fit over PS pulley) so I do wonder if there are different pulley setups or if it was just a typo.
UAE Rennlist Ambassador
Now, i found some nice yellow dots on each pulley, which indicated their relation to each other.
I did mark them before i remove them, but found out that the pulleys were already marked.
Strange to see that crank bolt just loosened off.
