Megasquirt Accel/Decel Setting?
Hello,
Trying to get it tuned and don't have a baseline----very jerky to drive.
Greatly appreciated if anyone could supply the following:
TPS Threshold---of MAP Threshold
Accel time
Decel Fuel Amount
TPS or MAP Base Rates.
Many thanks in advance.
Cy
Accel time
Decel Fuel Amount
Cy
congrats on getting it running! Always keep in mind that the VE table is paramount to achieving excellent throttle response. I had the best luck using mostly TPS enrichment with the threshold between 2.5 and 10 percent. The MAP and TPS lag factors are extremely important as well. Do some data-logging and see what works for your setup. ALSO: depending on you injectors, you may be able to get away with more squirts per cycle. If you can get 2 simultaneous or 4 alternating without compromising idle, that should help (I think haha). I've been away from my car for a few months so my memory is pretty foggy on all this stuff.
