How do I fix my dropping door?
Hi Guys,
I've been meaning to sort this problem out with my drivers door ever since I got my car...the bottom part of the door seems to ' kick out ' slightly everytime I opem my door causing it to rub on the bottom 6 inches or so against my front fender....I know its not the hinge that has sagged....I believe its a weld that has broke free from within the door that keeps the door skin held.....any body have this problem and more importantly know the best way to fix it?.....If I knew exactly where the weld was on the inside I was thinking of drilling a hole in the door from the outside and tack welding it back in place....grind off and repaint that section etc...
Hoping to hear of a solution!
Thanks guys
John.
Thanks guys
John.
I have seen the hinge welds fail. This will cause a sagging door, but it's pretty easy to reweld.
If you're seeing it in another location, you may have to do more investigating to figure it out.
Nope...just the bottom hinge weld has come away....Its coming off tomorrow and hopefully the problem will be sorted for once and for all...
I have this seen once before and the problem was that someone had his weight on top of the door so that after that the door scraped the sill.
So to fix it we just pushed to door up while it was open ; this means there was flex in the door itself, the hinges were just fine. No more problems afterthat.
Hermpie
Hermpie
