saratoga top
You would have to replace the two rear latches with the receptacle pieces that the arms fit into. You could probably rob them from a regular roof, trim them down, drill a hole through the center, and mount to the roof. I just don't know if mounting using the existing holes in the roof will align everything properly.
depends on which model you have. more info in this thread;
http://forums.pelicanparts.com/showthread.php?t=303141
